TwinTurbo.NET: Nissan 300ZX forum - That is for CAL spec, fed is 94-95
Subject That is for CAL spec, fed is 94-95
Posted by Fast300 on July 01, 2008 at 12:29 PM
  This message has been viewed 177 times.
In Reply To Re: It all depends on the software that is in the JWT ECM. posted by BigA on July 01, 2008 at 06:23 AM
Message The 90-92 will work in the 94 however those years had AIV,s.
You would have to get the numbers off the chip and ask JWT if the software has the idle software for the 90-92 or 93.
If it has the older software it will idle a bit rich but will run fine otherwise.
If you plan on custom software it should be fine the idle software is mute.
Also the auto's have a differant VTC setting.
